OK guys update time.....................
Havent updated for a while as have been working some ridiculous hours, which is why I'm home now. But more on that later.
Frankenzuke first....................
So the corners of the front bar needed adjusting as the huge 37" tyres were hitting it on full articulation.
This is what I thought needed removing.
So I got it on the bench ready for cutting.
Tried it back on the car.
And on full articulation to check the clearance.
These are the bits I cut off.
Cut the other side to match.
Cut a cardboard template of the piece I needed to cap the ends off and cut some steel on the guillotine.
Tacked it in place.
Quite pleased with how it looks.
Tacked the other side on and checked for clearance.
Got it back on the bench for welding.
With the top of the bumper off I could look at reenforcing the winch tray.
My concern was that the winch tray obviously bolts to the chassis but then the actual winch bolts a lot higher up. OK its only a little light weight car, but on a difficult winch pull it might bend the tray.
So my solution was to make some braces out of some thick steel.
That would pick up 2 of the holes in the front recovery hooks and bolt to the top corner of the winch tray.
The other side need a notch to clear one of the steering box bolts.
I then tack welded the rest of the bar onto the winch tray.
And then got the whole thing on the bench to be fully welded.
Fully welded it and then smoothed down all the welds with a flap wheel disc in the grinder.
My boss gave me some LED spot lights for it.
Not sure if I like them or not. they feel nice and solid and are all alluminium.
Put the bar back on the car so we could position the lights and drill more mounting holes if required.
I thought they looked OK in the standard Vitara spot light mounting holes.
Still not sure if I like them or not. Opinions please?
Took it off and hung it up ready for a few coats of primer.
Followed by some coats of black enamel.
Needs a few more coats but thats as far as I got last week.
We also got another Suzuki stripped.
I lifted the engine out.
I had another little project to do, mounting an air tank under the tray of a customers new truck.
Bent up, drilled, notched and painted a piece of steel.
To bolt up under the rear passenger corner.
1 tank fitted.
I made the bracket to take 2 tanks for when the guy upgrades his single cylinder ARB compressor for a bigger one.
All connected up.
Michael picked up some steel checker plate.
2 strips for the tops of the new rock sliders hes bought for his new 80 that were building, and 2 strips for the top of the sliders on LJ. I like the look of how my sliders look being open on the tops, but it means a lot of crap sprays up the sides of the truck when off road, so I've been thinking of closing them off for a while.
These are the sliders he bought. We worked out that it would probably cost him more for me to make them than he could buy them for so it made more sense to buy them already built. Only thing he did do was buy them bare as opposed to powder coated which is how the guy usually sells them.
Layed the checked plate on top and worked out what needed cutting off the ends.
Cut the ends on the guillotine.
Checking the curved ends were correct.
Gave the ends a final clean up with a flap wheel disc in the grinder.
And welded them on.
Got the one done Friday after work but ran out of time to do the other one.
As the company that does our electroplating was picking up a load of stuff today Michael wanted to get the sliders done at the same time. They will then get powder coated black.
So this morning my first job was to cut and weld the other plate on. Only before I got to work I didnt feel too good and my vision went a bit blurry. Thought I'd be ok so went to work, within half an hour of being there I had a really bad headache, was burning up and felt sick.
I struggled on and got his slider finished and then told my manager I wasnt well and he sent me home. Hence why I've now found some time, while recovering in bed to update the blog.
I suspect I may have over done it the last week or 2. Last week I worked over 75 hours.
Anyway thats enough about me, back to the update...........................
The plasters had finished plastering my room and the spare room.
As I needed to give the walls and ceiling 3 coats of paint Michael suggested using his paint sprayer.
It worked well and the walls were soon painted.
Spare room about to be sprayed.
I did the cielings (or roof as Michael calls it, despite me contiunaly correcting him in that the roof is on the outside, maybe its an Aussie thing!) the traditional way using a roller.
Saturday morning I built and fitted the new wardrobe door frame in my bedroom.
Made a start fitting the arcitrave and skirting boards.
While Michael fitted all the new power sockets and lights.
I painted the window and new arcitrave and didnt have to bother cutting the paint into the glass as were getting new, much thicker glass fitted this week.
The spare room still needs quite a bit doing as we ran out of skirting board.
Did get the new wardrobe door frame fitted though.
And the arcitrave around the door frame.
The painting in my room is now virtually finished, just a few bits to touch up.
Michael vacumed and then mopped my floor as the carpet is going to be another 10-12 weeks as its being specialy made to order in South Africa.
We picked up the rest of the timber, as well as all the timber and fittings I need to build a shelf in each wardrboe with a hanging rail beneath.
I'm hoping to move back into my room tonight, but we will have to rig up a temprorary make shift curtain.
It wont be completely finished for another month or 2 as we wating on the carpet from South Africa, the curtains and drapes are being made now by a local company and might be another 3-4 weeks. The doors and sliding track have being ordered from a specialist door company and could be another few weeks away.
The thicker glass is going in the windows this week and then were getting them tinted with a one way tint.
Its going to be so nice having a nice room that I'm proud to bring girls back to.
I havent forgotten about LJ and will try and start sourcing and ordering all the bits I need this week.
I want to get these 2 rooms finished on the house then I'm not doing anymore building work for a few months, and will instead concentrate on LJ.
