NATO hitches on a 100 series?
pugwash
Hi All,
have a NATO hitch for sale on e-bay and someone's asked if it will bolt straight up to a 100 series standard rear bumper?
they do on an 80, but I dont' know on a 100
Anyone know?
Many thanks,
James
Not with out cutting the plastic bumper and then im not sure the cross member is strong enough to use for towing with out bracing it or if the bolt pattern match up.
Just been out and measured it - The 100 series cross member bolt pattern is 4 bolts, 85mm apart centre-center horizontally, and 45mm vertically. The top two look like M14 threaded holes. Is that the same as an 80 series ?
