"An optional feature offered by Bowler was a lift device that could lift the vehicle past the lowest travel of the front and rear suspension. The lift was intended to be used to assist in digging the vehicle out of soft ground or to facilitate changing a wheel. The lift device consisted of a large steel plate on a hinged sub-frame attached to the underside of the vehicle frame between the front and rear axles. The lift was lowered by a hydraulic ram that was controlled from inside the vehicle. The lift plate also served to protect the underside of vehicle when raised"
