- Apr 10, 2016
a few jobs done this weekend:
3 shocks replaced, unfortunately the bolt snapped in the spring seat at the right rear so the seat will need removing and the bolt drilling out.
The gas struts were replaced, this was easier than expected. The tailgate is a job to close now!!
The hole in the rear wiper water pipe was found and dealt with. It no longer leaks through the headlining.
The rear wiper operation was investigated. It only works at normal speed. The intermittent doesnt work and it wont park. It just stops where it is when turned off. Suspect the wiper control relay may be a problem, but how to test it?
Anyone else been busy?
