MisterCruiser
- May 28, 2014
Theres a bit of play in my front wheel when I grab it in the 3 and 9 position. I've a new inner tie rod and outer track rod on the cruiser and the play is still there. When Ive the outer track rod balljoint disconnected from the hub and try to push/pull the entire track rod struts I cant detect any play so I think the rack end is ok?
Ive also happen to have a new lower balljoint fitted to this side of the cruiser too.
So where can the play be coming from, could the rack mounting bushings cause it? Or a wheel bearing? Can the bearings on a 90 cruiser be adjusted? Whats the most likely culprit?
Thanks in advance.
Thanks in advance.
