Support bracket wanted.
Julian T
south_africa
Looking for the LHS support bracket between the block and bellhousing with bolts.
Toyota part number 33119-60031 or superseded number 33119-60070.
Of the three photo's I am looking to replace the broken one obviously, it mounts between the block and lower half of the gearbox bellhousing where you can see the clutch slave cylinder.
The one on the right is shown in situe as a reference.
Amayama list the part from £25 to £50 ball park, obviously pre vat and shipping, Toyota price is £140 pre vat so checking club availability first.
Thanks.
Get it welded....my old 91 80 series had the exact same issue when I bought it....took it off and welded it up.... may years later and now with another owner it had never cracked again
Looks like it's been incorrectly tightened. All bolts must be done gently up until all the sideways/up-down movement has been taken up before fully tightened.
Sadly the other half is missing, I would dearly love to know for how long, I only found this when I dropped the sump to do the con rod big ends.
Makes you wonder if the part number supersession is because of a known issue with them failing .....
It's only a brace and as such shouldn't be subject to undue load once correctly installed.....
