aussiearthur
- Feb 1, 2022
G’day team,
long post, but really need some help, as this problem is killing me!!! And also my wallet.
Car is:
- 1kd 2007
- 213km
- auto
Fault:
- whether hot or cold, there is a fairly significant amount of hesitation/ surging occurring at 2100rpm, 2300rpm and 2400rpm. The car physically slows and rpm drop, lasts about a second and then surges forward. A few seconds later it repeats, and will continue until I move out of this rev range.
- no issues evident at other rpm ranges
- it is repeatable every drive.
- am concerned that this is damaging the engine.
- NO fault codes
- no smoke
- car runs beautifully otherwise.
- issue occurs using either the accelerator pedal or cruise control (so have assumed it’s not an accelerator position sensor issue).
There are a few threads in Pradopoint and New HiluxD4D forums which state similar issues (vehicles have similar manufacture dates too), but none of them ever reach closure on this issue.
I have:
- checked and cleaned heaps of electrical connections
- cleaned MAP and MAF sensors and filters, cold start idle values look ok.
- replaced MAP sensor
- cleaned EGR valve, the manifold and the cooler.
- turbo and stepper replaced at about 190k
- fuel filters (x2) and air filters recently replaced.
- SCV replaced ( with the long version)
- injectors replaced.
- swapped the whole throttle body with another.
- I performed a fuel leak test via Techstream, which saw the system hit its target set point and hold there with no codes thrown.
I feel like this is related to RPM, as I can consistently repeat this issue at the stated rpm levels.
could there be a link here to a sensor that is feeding the ecu some dud information - ie transmission speed sensor, egr valve, or a fuel temp sensor???
I would be absolutely grateful for any assistance on where to look next.
kind regards.
chris
Car is:
- 1kd 2007
- 213km
- auto
Fault:
- NO fault codes
- no smoke
I have:
kind regards.
chris
