MisterCruiser
- May 28, 2014
Can any 90 series owners tell me how long it takes for their cabin to start blowing warm air from a typical cold start?
Also, can ye tell me if after a normal drive, does your entire radiator get warm evenly to touch? Or is it normal for only the top 1/3rd of the rad to be warm and the bottom 2/3rds stone cold under normal light driving conditions. I first noticed my rad being like this about 3 years ago.
I suspect my rad is partially blocked because the bottom 2/3rds seems to be always stone cold (these fins aren't in great condition either) and also because my cabin blows warm air extremely quick, like after 5 mins and less than a mile driving. For a big 3.0L engine I always thought the engine heated up very very quick and blew hot cabin air extremely quick too. Just wondering how this compares to other 90 series cruisers? I reckon it's the original rad. I've a new water pump and thermostat when I done the timing belt a year or 2 ago.
I also have a mk5 Golf 2.0L diesel and it takes about 10/15 mins + 5/6 miles before I start to get warm air, it's easily takes twice or 3 times longer to warm up in comparison to the cruiser.
Is there a way for me to check / test that the rad has full circulation and not half blocked or is checking its entire surface for warmth by hand a sufficient test? I suppose I could disconnect the in and out hoses and flush water through it and see if it comes out the bottom? But any good way to know without removing / draining it? Although, I think I did flush the rad when I changed the thermostat and put new coolant in when I done the timing belt so the rad must have drained out the bottom for me then, I remember opening the plastic drain tap. Maybe it's not completely blocked but not as efficient at letting proper amount of coolant through bottom half and hence bottom doesn't get warm? I had considered renewing the rad when doing the timing belt due to the not so great looking fins from half way down but it wasn't leaking or anything so I left it. Half thinking of replacing it now but just interested in seeing how other rads behave regards fully warm before I replace something that doesn't need replacing.
I gave it an oil service there over christmas and noticed when I switched the engine off with bonnet open I could hear coolant noises, just like typical hissing / pressure noises around the top of the rad and then I could hear drops of coolant in the expansion bottle. I know after a long hot drive coolant will return from the expansion bottle to the rad as the engine sits cooling down, but is it normal for coolant to make it's way into the expansion bottle after just switching off a pretty much cold engine?
I'm trying to keep an eye on it and do some checks now before I start to fear the worst
