MisterCruiser
- May 28, 2014
There's something strange with my fuel tank, the straps don't fit around it properly, they were only bolted on at 1 end and the other end tied up since I owned it. I know the previous owner had the tank off.
Are they correct places to bolt each end of the straps in my pics below?
In the first pic, where I circled in red indicates where that end of the strap will only reach to when the tank is fitted. I've the tank up as far as it goes, the 2 protruding box sections of the floor match up with the indents on the to p of the tank and all my pipe work / filler pipes match up. But the tank straps don't reach up to the point where they can be bolted in, I can only bolt them in using an extra long bolt and threading the bolt in partially, the tank is free to move and sway like this. I can tie wrap it secure but would rather have it bolted or at least figure out why I can't bolt it. Is there something awry in my pics or is it possible the straps have deformed and gone out of shape.
If someone happens to have a pic of the fixing points on a colorado that'd be great, or has anyone had this issue, is it common the straps can go out of shape / wear and not reach?
In the parts diagram below, the circled red bit is where I am trying to bolt the end of the strap, so correct point, just won't reach.
