stuzbot
- Jan 20, 2021
I brought this up in my 'Got One at Last!' thread:
But it's got a bit lost in the midst of all my other froth-lipped tomfoolery there. So, since it's an important job I don't want to screw up, I'll put it in a separate thread.
I've ordered a new radiator, new transmission filter & gasket and plenty of ATF and coolant from Roughtrax, as I'm going to preventatively overhaul my entire cooling system.
Now, I've read the various threads about draining the transmission sump, refilling, driving a bit to allow the new ATF to dilute the old cruddy stuff.... rinse and repeat until you've purified your ATF as much as possible. But I still have some queries about what I'm planning
1: If I remove and replace radiator too, I'll obviously lose whatever ATF was in the oil cooler section of the old radiator, as well as what was in the transmission sump. So is it just a case of topping up with that much extra to get back to where I was, or is it more involved. ie does the oil cooler section of the new radiator need to be primed or bled to remove the air and fill it with ATF, or will gravity do the trick?
2: Fitting the new transmission filter means removing the transmission sump. Will this also eject more of the old cruddy ATF than comes out the drain plug? I imagine it will. And, when I remove the old filter, will that cause even more old ATF to drain out? Just trying to get a handle on how much capacity I'll be needing in my catching tub to cope with it all.
Got One at Last!
Great news you found what looks like a nice example of a Colorado. If you lived up I need north east Scotland like i do, you would appreciate the heated seats on a -10 degC snowy morning .
www.landcruiserclub.net
