Tubular winch bumpers in the UK ?
Grimbo
Front of my 80 is looking a bit sad as slight rust on the centre section of the bumper and some idiot managed to scrape the corner section while it was parked in a carpark .
I could sand blast and repaint but I'm thinking I want to put something on the front that will do more damage to the idiots who drive into parked cars ..... the standard corners are a bit soft .
A quick look about and nothing takes my fancy that I've seen ........ I like the look of the front bar on Shaunno's 80 .....Sooty..... but nothing available here gets close looks wise and certainly not build quality wise ......
A certain LR ( cough cough ) specialist...... Terra Firma do some nice looking tubular bars but not for Landcruisers .......
Anyone seen anything any good for 80's
Think most are custom built and if you go that route get yourself a good welder and do it yourself the way you want it or find a good fabricator who will make it for you if you tell him what you want
I could make one but it would end up being indestructible and weighing 750 kg.......
Landrover bumpers are readily available cheap as chips so buy one and modify to fit .
Apart from by the time I had made it wide enough for an 80 and then made it fit an 80 it would be like triggers broom ;-)
Looking around there are some better looking 100 series ones so that's probably a better starting point .....
try this web site, got one for my 90 and it has prove it cause more damage to the other vehicle a few times but it will cost
bumper
I believe a discovery is a bloody close match for the width of an 80 so one of them modded could be a good way to go
