thelal
- Mar 11, 2010
Suffering with water on interior lower carpet material on the bottom inside of both middle doors after lots of rain
I've changed the outside bellhousing (if thats the name) plastic trim and that helped a little
I've opened up the doors and can't figure out where the water is getting in.
The inside cardboard trim is getting soggy and fed up trying to dry them out.
I suspect I need new plastic (see thru) membrane thats got black tacky 'glue' to keep the water out.
Any ideas on this part number or what else could be causing the problem.
