- Nov 19, 2010
this mornings job was the N/S wheel bearing on the 120. Simple and straight forward if you buy the ready built hub and bearing assembly. I hadn't driven this for a good while and only that Maria said the ABS light had come on had come on did I have to investigate. Diagnostics said foreign body on ABS sensor and when I jacked the wheel up a good 10-12 mm play at the wheel, so ABS sensor had bearing remains on it.
Hub and backplate installed, gave the backplate a bit of attention.
Changed the ABS sensor as well.
Installed the first of 4 genuine drop links. This was mentioned on the last MOT that 3 of them had slight play so I thought I'd replace them when the wheels were conveniently off. Also tidied and painted the brake pipe, preventive maintenance etc.
