Hi everyone, whats your opinions on fitting 305's or 315's with a 4" suspension lift? is there cautions to consider when fitting 315's in terms of the king pins? I've heard of people's failing when fitting 35" tyres.
I'm running 305s on a 110mm suspension lift and I have had no known problems with the "king-pins" although I too have been "warned" that they may fail prematurely.
MHO is that these trucks are built way above a "normal" factor of over-engineering. There are several components which would be potentially overloaded by the use of bigger wider and heavier tyres, namely the CVs, drive-shafts, wheel bearings, steering ball joints and even the diffs. I don't have any experience of premature failures of any of these components after 8 years of running oversized tyres.
I'm on 305/70/16s so my rolling diameter is marginally over 33" and I have no experience with 35". I really do think that the biggest concern with oversized tyres should focus more on the effects on gearing, top speed reduction, reduced braking efficiency due to the extra braking needed to compensate for the grater inertia of a heavier tyre and such like.
The rest of the scaremongering is, IMO, just the "skinny brigade" trying to justify its existence
Seriously though, these trucks are built for the apocalypse, it doesn't make them foolproof, and I may be a fool, but mine has tolerated me for 8 years with few complains in that department....
