There's an eternal debate on what is "better" a body lift or a suspension lift and for me, it all depends on what you are looking to get from the "lifting" process.
If you want longer suspension travel, then a body lift will do nothing to assist. If you only want more body clearance from the ground, then either will give you useful results.
One factor which is generally argued in favour of a body lift is maintaining a lower centre of gravity, whereby most of the heavier bits (engine G/B T/B etc.) stay put, and only the body goes up.
So, carefully consider what you need, is it just to accommodate bigger tyres? If so, maybe a body lift is enough.
Take care with a body lift, I wouldn't recommend much more that 3" if 2" is not enough. Then I'd go for a combination of the two.
Mine's a 110mm suspension lift, it's high for offroading and works well on the black stuff too. JMHO...
