Hopefully. If its a diesel it won't be ignition problem. Either fuel or air starvation, problem with injector pump or it could just be the H engine, if that's what you've got, hates hills! Mine struggles with steep inclines and does require working the gears otherwise it hasn't got the power to see you up there and could be a reason for stalling?
Good luck
David
