Hey guys and Girls How you going?
This seems to be the place of Smart Landcruiser owners
Could i have some advice please?
I have a wonderful NZ new 100 series 2001 Landcruiser 4 speed Auto (with the towing package).
Rego JQA129
Toyota Land Cruiser (HDJ-100R-NGPEZW)
Engine model: 1HD-FTE
History 450k mostly 1.5+ hours motorway use. Well maintained trans oil/filter changed every 100k. At about 370k The expensive long life ATF put in. 1st 180k Previous owner no towing. Last 270k a bit of towing 2.5ton wake boat.
I have seen the trans over temp light come on twice (stuck in traffic going up the mountain just above idle. Dropped it into 1st gear light went strait off) done another 60k and never seen it happen again. I Don't use it a lot now just occasionally towing the boat to the ramp or on clients farms
Problem is left home pulled onto motorway (start of normal 1.5 hour trip to Town) cruising at 100km 5 min later it dropped out of top gear revs came up so turned around went back home grabbed the girlfriends car
Done it 3 times in a row so i have a issue!
I have done some research and I have heard that the A442f can get a faulty valve (if overheated) or just the valves get blocked up which needs demagnetizing and cleaned them out.
Iv got a set of new solenoid valves coming.
30 years ago I was a mechanic and had to clean up/reckon some turbo400's and 350's (1 in my in my bro's fJ40 with 350chev) so I think I can Drop the valve body and replace them myself.
What do you guys think please? anything ells you think i should look at please.
Thanks for any advice
logan![:) :)](/custom/images/smilies/pack2/icon_e_smile.gif)
Rego JQA129
logan
