CARROT CRUNCHER
- Mar 9, 2013
I'm retired & do far fewer miles than before, my truck spends it's time sitting in the garage and goes to the supermarket once a week. It needs to be used and enjoyed, the engine's as smooth as silk on both petrol & lpg. It never fails to make me grin like a big kid whenever I drive it, I've never off roaded it nor towed anything either. It's never been in an accident so nothing has ever been bent, the rear bumper corners have been resprayed more than once over the years, that's supermarket car park signs for you! There are no chassis welds whatsoever. Body panels that have succumbed to rust have been repaired, which has in some cases required cutting out, making good, welding & repainting.
![20240308_132719.jpg 20240308_132719.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184854-491333164d1767b993dc78380ce877d4.jpg)
![20240308_132443.jpg 20240308_132443.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184855-2777f3a159eb85bf8a0e1d94f38f1660.jpg)
![20240308_132514.jpg 20240308_132514.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184856-3ef69c26a30d55c59d73cb06e3fd5021.jpg)
![20240308_132523 - Copy.jpg 20240308_132523 - Copy.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184857-da61dc315051b386061fcb32054f45bc.jpg)
![20240308_132539.jpg 20240308_132539.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184858-bcf24375354f4a145f20a2865d759778.jpg)
![20240308_132749 - Copy.jpg 20240308_132749 - Copy.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184859-da1095d3f476e70a374d0a25ff452ddb.jpg)
![20240308_132807 - Copy.jpg 20240308_132807 - Copy.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184860-bcefb5ea7257a88126f104bfba55b949.jpg)
![20240308_132814.jpg 20240308_132814.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184861-80036dd2372afda1293d7fdc07e62042.jpg)
![20240308_132825.jpg 20240308_132825.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184862-78e85ac5bad4f463c554bd5bfc5ea4bd.jpg)
![20240308_132830.jpg 20240308_132830.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184863-2910ffce80e1becfb8dd475fd27cc28c.jpg)
![20240308_132853.jpg 20240308_132853.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184864-d409ea86a288559ac3731275371745d5.jpg)
![20240308_132859.jpg 20240308_132859.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184865-c1fa3d6ba133e3b611f0e94a48571643.jpg)
![20240308_132912.jpg 20240308_132912.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184866-904892fe57941324fddecd301f12611c.jpg)
![20240308_132923.jpg 20240308_132923.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184867-eca16e6cfa65a9e095e2e3e4980f8384.jpg)
![20240308_132929.jpg 20240308_132929.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184868-4471755ad4802be5bbf8c0995f4878fb.jpg)
![20240308_132957.jpg 20240308_132957.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184869-a833666e5dcb108e8c228589af6f5236.jpg)
![20240308_133002.jpg 20240308_133002.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184870-c0c33c37bbc5b49dc2f18e8e8c510577.jpg)
![20240308_133040.jpg 20240308_133040.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184871-5e3506aa9047df60d03af75b206e5008.jpg)
![20240308_133048.jpg 20240308_133048.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184872-acc7483443d1d9876b9caf3d89e4924f.jpg)
![20240308_133057.jpg 20240308_133057.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184873-da864481d1fa22a10e3a5eda2c8f88b0.jpg)
![20240308_133117.jpg 20240308_133117.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184874-62d7d4a2d2b2201a504e3a2148f1c404.jpg)
![20240308_133124.jpg 20240308_133124.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184875-81d5ea43218df4d7a5cad23ec345bece.jpg)
![20240308_133149.jpg 20240308_133149.jpg](https://www.landcruiserclub.net/community/data/attachments/184/184876-3895f61e7d134ce918b8e26d9d1ac106.jpg)
- 1996 UK 80 SERIES 4.5 24V (1FZ-FE) AUTO
- 8 GREY LEATHER SEATS NO TEARS OR SPLITS
- 3RD SEAT ROW REMOVED-IN DRY STORAGE AT HOME WITH ALL FITTINGS
- BRC BASED (ZAVOLI) MULTIPOINT SEQUENTIAL LPG SYSTEM + FLASHLUBE FITTED
- 90 LITRE TOROIDAL LPG TANK IN SPARE WHEEL BAY UNDER THE TRUCK
- BOUGHT BY ME DECEMBER 2005 WITH JUST UNDER 97K MILES ON THE CLOCK
- FULL SERVICE HISTORY & ALL RECEIPTS IN MY OWNERSHIP
- ALL MOT’S SINCE 2005, CURRENT TILL DECEMBER 2024
- CURRENT MILEAGE 229031 AS AT 13/5/24
- BRAND NEW SHORT ENGINE FROM AMAYAMA FITTED AT 213100 MILES (SEPT 2019)
- NEW MASS AIRFLOW (MAF) SENSOR
- NEW THROTTLE POSITION SENSOR (TPS)
- NEW LONG-LIFE NGK-LPG1 SPARK PLUGS
- NEW TIMING CHAIN
- EXHAUST DOWNPIPE REPLACED & 2 NEW OEM KNOCK SENSORS APRIL/MAY 2024
- USES 5W/30W FULLY SYNTHETIC OIL AS ITS A NEARLY NEW ENGINE
- WATERLESS COOLANT WON’T BOIL UNTIL 180 DEGREES & NEEDS NO ANTIFREEZE
- “LONG LIFE” BRAND STAINLESS STEEL 3” EXHAUST WITH CAT DESIGNED FOR LPG
- NEW OEM DISTRIBUTOR CAP & MAGNATEC UPGRADED HT LEADS 2020
- NEW REAR DIFF LOCK ACTUATOR (OEM) SEPTEMBER 2022
- NEW REAR DIFF LOCK SEAL & CHECK THROUGH JULY/AUG 2022
- POWER STEERING PUMP REBUILT WITH TOYOTA REBUILD KIT
- ALL EXTERNAL BULBS CANBUS LED’S (RESISTOR FITTED TO INDICATORS)
- ADDITIONAL INDICATOR CANBUS RELAY TO BACK UP RESISTOR
- ALL INTERNAL BULBS (EXCEPT ONE) LED’S
- ALL INSTRUMENT CLUSTER & HEATER CONTROL BULBS LED’S (“D” WORKS!)
- LAZER ST2 SPOTS & FOGS (E9 CONFORMITY) NO MOT ISSUES, GREAT LIGHTS
- 4 X NEW MILNER’S SHOCKS & SPRINGS NOV 2021
- ALL 5 WHEELS PRO REFURBED + NEW CHROMED WHEEL NUTS MID 2023
- 8 X “VERY GOOD” PART WORN TYRES + 1 UNUSED SPARE, ALL BFG A/T KO 2
- NEW BOSCH BATTERY DECEMBER 2023
- WAXOYL (CLEAR) UNDERSEAL INCLUDING RUST INHIBITOR DECEMBER 2023
- “B” SERVICE + AT 228,506 MILES DECEMBER 2023
- REAR LID GLASS OUT, RUST CUT OUT & MADE GOOD & RESPRAYED FEBRUARY 2024
- RUST HAS BEEN KEPT ON TOP OF, LOWER TAILGATE, UPPER TAILGATE, REAR PASSENGER DOOR BOTTOMS, SILLS & BONNET STONE CHIPS
- STARTER MOTOR FITTED NON-OEM, SPARE IS ORIGINAL & WORKING DENSO
- AUTOWATCH THATCHAM 1 ALARM & IMMOBILISER FITTED
- GOODYEAR FRONT & REAR DASHCAMS HARD WIRED TO REAR VIEW MIRROR
- SEPARATE REVERSING CAMERA HARD WIRED TO KENWOOD MULTIMEDIA CENTRE
- EXTRA AFTER MARKET 56 LED/40 CM HIGH LEVEL BRAKE LIGHT FITTED
- DOUBLE DIN KENWOOD MULTIMEDIA CENTRE, 7” TOUCHSCREEN, BLUETOOTH & MP3
- CLUSTER TRIP CLOCK FAILED A FEW YEARS AGO, THERE’S A DIGITAL TRIP WITHIN THE KENWOOD MMC/SATNAV ON THE DIGITAL SPEEDO SCREEN, A VERY USEFUL SCREEN
- NEW FRONT WINDOW REGULATORS (NON-OEM) 2020ISH, WORK WELL ALL SEASONS
- ORIGINAL OWNERS H/BOOK & SERVICE BOOKLET, FULLY COMPLETED IN MY OWNERSHIP
- HAYNES WORKSHOP MANUAL COMPLETE WITH SCRIBBLES & TEA STAINS
- QUALITY REPLACEMENT LEATHER STEERING WHEEL COVER
- CARGO NET
- HEAVY DUTY UNIVERSAL RUBBER MATS FRONT & MIDDLE
- DRAWFUL OF ASSORTED “HANDY BITS” ACCUMULATED OVER THE YEARS
- 2 KEYS, 1 NEW FROM TOYOTA ABOUT 10/12 YEARS AGO, CENTRAL LOCKING OPERATED FROM THATCHAM ALARM FOB, WHICH ALSO HAS A SPARE FOB
- DOOR LOCK BARRELS REPLACED, ALL DUPLICATED WITH IGNITION LOCK SERIAL NUMBER
- HEADLIGHT WASHERS REMOVED AS BOTH FRAGILE & PRETTY USELESS, REPLACED WITH 2 X 60CM LED DRL/INDICATOR STRIPS LINKED TO SIDELIGHTS & INDICATORS
- “CHERISHED PLATE” P80 CRU INCLUDED
- LOCATED AT KEEPERS ADDRESS IN SUFFOLK & V5 PRESENT
MINOR MATTERS
- AIR CON NEEDS NEW CONDENSER, COMPRESSOR & DRYER. NB: USE OEM AS I DIDN’T & THEY DIDN’T LAST 5 MINUTES
- HEATED SEATS NOT WORKING, PROBABLY DISCONNECTED UNDERNEATH AS SWITCHES WORK, NEVER GOT THEM DONE AS MY BACKSIDE DOESN’T GET THAT COLD
- REAR AIR CON FEED DISCONNECTED AS AN EXTERNAL PIPE CORRODED & “NLA” AT TOYOTA, PROBABLY COULD BE REINSTATED AT LITTLE COST WITH GENERIC PIPING
- SMALL STAR CHIP AT TOP RIGHT OF WINDSCREEN, HASN’T SPREAD & NOT A MOT ISSUE
- FOR AT LEAST 10 YEARS SMALL BULLSEYE STONE CHIP NEARSIDE HEADLIGHT, SEALED WITH CLEAR REPAIR TAPE, NO WATER INGRESS OR CONDENSATION, NOT A MOT ISSUE
- SMALL (1.5 CM) CRACK REAR NEARSIDE LIGHT LENS, BEEN LIKE THIS FOR YEARS, NO WATER INGRESS OR CONDENSATION, NOT A MOT ISSUE
- SMALL AMOUNT OF RUST BUBBLING EVIDENT TO VERY BOTTOM FRONT CORNER OF NEARSIDE FRONT WING AT JUNCTION WITH BUMPER & ARCH FLARE
- HEATED REAR WINDOW WORKS ALBEIT SLOWLY, CURRENT GETS TO IT BUT THE ELEMENT IS 28 YEARS OLD SO DOESN’T RUSH, NEVER REALLY CONCERNED ME AS ALWAYS GARAGED
- VERY SLIGHT VERTICAL PLAY ON STEERING WHEEL OF ABOUT 2MM, ITS BEEN LIKE IT SINCE I’VE HAD IT, IT’S NEVER BEEN A PROBLEM, IT DOES GET PICKED UP ON SOME MOT’S BUT NEVER A FAIL, IT’S A MYSTERY
£13,500.00
PAYMENT BY ELECTRONIC TRANSFER ON THE DAY, WHEN FUNDS IN & CLEARED MY BELOVED TRUCK IS YOURS
GIVE IT A GOOD HOME!
