Howmanygoes
- Jan 14, 2019
After a sounding board.
Truck developed a vibration around the time I fitted front bumper and winch. Can't see anything wrong or loose here. I also had the transmission fluid changed as I had a leak on the pan.
Vibration comes on about 50mph at 1800rpm then disappears about 60mph circa 2000rpm. No noticeable vibration at those revs stationary on the drive. Whilst driving I knocked into neutral and vibration was still there, though slightly less prevalent. No vibration through the steering wheel. Feel it most through the floor
I dropped out the rear prop and replaced the UJs and had it rebalanced. Still vibrating but a slight different one now, the prop balance was way out. I had the wheels balanced 3 of 5 balanced ok 2 didn't. 2 good ones on the front and the better 2 on the rear and the worst on the spare. I've now removed the front prop and replaced the UJs. This is going for balancing tomorrow. Also checked transmission mount whilst under there, looks good.
All 4 Wheel bearings were done less than 5k ago and had mot just before fitting of the bumper and transmission drain.
So if the balancing tomorrow doesn't work I've run out of ideas and open to suggestions.
