- May 23, 2015
HANNIBAL 1.4 METER DELUXE ROOF TENT PLUS JUMBO KIT AND DROP DOWN ROOM
ONE OF TOP RTT BRANDS WITH HIGH QUALITY DESIGN AND MANUFACTER FROM SOUTH AFRICA
ALL IN EXCELLENT CONDITION, NO LEAKS OR TEARS
Price - £1,250
Sleeps: 2 adults, very comfortably
Dimensions
Packed size: 250mm high x 1.4m wide x 1.2m long
Rigged size: 1.3m high x 1.4m wide x 2.45m long
Weight C. 50Kg
CAN BE ORIENTED TO HAVE ENTRANCE AND LADDER OVER BACK, BONNET OR SIDE OF VEHICLE
TENT DESCRIPTION
TENT CANVAS: 380GSM RIPSTOP POLY COTTON; STRONG YET ABLE TO BREATHE
SEAMS: DOUBLE STITCHED; EDGED WITH BINDING. ALL SEAMS HAVE BEEN WATERPROOFED
STITCHING: SUPERIOR STRENGTH QUALITY THREAD (S25)
FLYSHEET: WATERPROOF 210-DENIER RIPSTOP OXFORD NYLON
FLY SHEET POLES: 4MM ELECTRO GALVANISED SPRING STEEL
ROOF TENT FRAME POLES: POWDER COATED OR ANODISED ALUMINIUM
HINGES: 3MM STAINLESS STEEL; LONG LASTING AND RUSTPROOF
BASE BOARDS: 12MM MARINE PLY FOR BEST INSULATION AND STRENGTH
ADJUSTABLE WINDOWS OPEN FULLY FOR BETTER VENTING
INSECT MESH ON EVERY OPENING; ALL UNZIP AND TIE UP SEPARATELY
ZIPS: YKK U-ZIPS ON ALL ENTRANCES ENSURE THAT YOUR ROOF TENT CAN BE TOTALLY SEALED AGAINST MOSQUITOES AND FLYING INSECTS. ALL ZIPS WORK.
75MM HIGH-DENSITY FOAM MATTRESS
MATTRESS COVER IS ZIPPED AND CAN BE REMOVED FOR LAUNDERING
SPACIOUS HINGES ALLOW FOR BEDDING TO BE LEFT INSIDE THE TENT WHEN CLOSED
INSIDE HAS STORAGE SIDE POCKETS
ALL POLES, GUY ROPES, WINDOW SUPPORTS, ETC
TWO PIECE ALUMINIUM LADDER INCLUDED EASY TO SLOT TOGETHER
BOLTS ONTO THE ROOFRACK
TENT COVER
UV STABILISED PVC, SEAMS ARE WELDED FOR ABSOLUTE WATERPROOFING
SOME WEAR ON ZIPS AT BOTH CORNERS BUT WORKS FINE
(A Brand new replacement 140 PVC cover is only £130 from Hannibal)
UNIQUE ELASTIC TENSIONERS INSIDE THE ROOF TENT PULLS IN THE SIDES WHEN COLLAPSING THE ROOF TENT
EXTERNAL TIE DOWN STRAPS ON ROOF TENT COVER PREVENT BALLOONING WHILST DRIVING; LOWERS WIND RESISTANCE; SAVES FUEL
JUMBO FLY SHEET AND DROP DOWN ROOM
THIS CONSISTS OF AN EXTENDED FLY SHEET, SPACER BAR KIT, GUY ROPES AND PEGS. IN ADDITION THERE IS A DROP DOWN ROOM CONSISTING OF 3 WALLS AND A GROUND SHEET WITH VELCRO ATTACHMENTS. THE 3 WALLS COMPRISE A WINDOW, A DOOR/AWNING AND A SECOND WINDOW, ALL WITH MOSQUITO NETTING.
WITH THE JUMBO KIT RIGGED THE ADDITIONAL ROOM BELOW CAN BE USED FOR COOKING ETC WHILE PROVIDINGI PROTECTIOO FROM RAIN/SUN/WIND OR AN EXTRA SLEEPING SPACE IF NEEDED.
MY EXPERIENCE AND CARE OF TENT
THESE TENTS ARE STRONG, WATERPROOF AND VERY COMFORTABLE. WE HAVE USED IT ON TRIPS TO ICELAND, MOROCCO AND SPAIN WITH COMMENSURATE MIX OF WEATHER – HOT, COLD AND WET. IT ONLY TAKES MINUTES TO SET UP OR TAKE DOWN.
LIKE ALL OUR OVERLAND GEAR IT HAS BEEN VERY WELL LOOKED AFTER. IT HAS ALWAYS BEEN PACKED AWAY DRY AND CLEAN AND THEN STORED INSIDE A GARAGE WHEN NOT IN USE.
TENT WAS RECENTLY WATER-PROOFED WITH A FABSIL DOUBLE COATING AND A WHOLE NEW TENT COVER FROM HANNIBAL ABOUT 3 YEARS AGO.
WE ARE ONLY SELLING AS WE HAVE CHANGED OUR SLEEPING ARRANGEMENS FROM A RTT TO A POP UP.
Please message me with any questions.
VIEWINGS WELCOMED AND ENCOURAGED.
COLLECTION PREFERABLE FROM NEAR PORTSMOUTH (OR POSSIBLE PALLETED DELIVERY AT EXTRA COST)
Price - £1,250
Dimensions
Weight C. 50Kg
TENT DESCRIPTION
TENT COVER
