100 series rear brake caliper toque spec.
rekab69
Hi Guys,
I have just serviced my rear brakes, callipers completely removed so I would like the torque specs for the caliper mounting bolts & the slider bolts too...
If there is a list of all torque specs any where that would be great..
Cheers,
db.
Slide pins 20lbs or 26 nm and calipers 76lbs or 103 nm thats from Max Ellery service manual EPTO18 you should be able to get one from RoughTrax hope this helps you but if in doubt do them up FT or to put it polite fluffy tight ta steve
