jordan_sorabjee
- Mar 22, 2021
I had a similar issue. It turned out to be a broken wire to the water temperature sensor. Its the one behind the Injector pump near the firewall, not the water temperature sender at the front. Simple change of the connector and sensor and problem solved for me.
