Knucklehead
- May 28, 2013
Hi,
I have been trying to track down a small coolant leak and had blamed everything from water pump to head gasket and all parts in between.
It was through pure chance that I finally noticed a drip while changing out my BEBs.
There is a small 2 inch hose just under the manifold. The following picture is taken underneath from the back of the block looking forward.
The metal pipe at the rear of the hose goes up the back of the engine and connects to a rubber hose and then through the firewall so thinking part of rear heater pipework.
The front metal pipe runs forward along the bottom of the block but I still haven't found where it ends up.
I have searched through my EPC and FSM but can find no sign of this right angle piece of rubber hose/pipe work.
Anybody replaced this hose/metal pipes and any idea of its name/part number?
I like to use OEM whenever I can but am starting to wonder if this is a PO botch job as the rubber hose seems a little half ass for Toyo.
Should be a real giggle replacing as can only get one arm at full stretch to reach it. Thinking I will need to take all the pipework off starting at the firewall to get at it properly.
I gave the clamp a small nip up but still have some of the red stuff escaping out.
Any thoughts regarding name/part numbers much appreciated.
Cheers,
Dave.
Cheers,
Dave.
