200 series reversing light
Chip
australia
Hi can anyone please tell me where I can pick up the reversing light wire on my 200 series? I want to add a light near the tow bar to make it easier to see the caravan when hitching up.
how about from the plug wot your caravan plugs into??
A lot of Australian 7 pin plugs don't run the reversing lights on a trailer, at least not in the same way that a UK or European plug does. If they're the double thickness ones then they might have a feed to do so.
It's something I'm thinking about on my 4Runner as well, I could do with a bit more light sometimes reversing up our driveway (especially when I'm avoiding the tactical coloured motorbike...)
Pin 2 may be used for reverse lights in standard wiring configuration, but as Ed noted, many installers don't bother in Oz. Many in fact use it for a positive feed for batteries which I don't recommend.
But aside from that, if your wiring doesn't already have a reverse feed to that pin 2, then you will need to pick off the reverse light from the back of the light fitting.
Yes I thought of that but the reversing lights are not wired to the 7 pin socket. :-(
I would not tap into the the reverse light as you may throw up problems with the canbus, you should be able to get a can bus friendly relay, A quick look on google and it seems the following relay will work and article;
10amp SY4050;
http://www.autospeed.com/cms/article.html?&A=112936
i would double check with someone who is experienced with caravan installations.
Ive just changed the standard 21w reversing bulb on the hilux to an 80w equivalent led - massive improvement for about £18.
I will find the link and pop it up on here for info.
The problem I found with the 95 being lifted was that I had unlit areas, wish id thought of led bulbs then. It would certainly light up a towing area.
the other option could be to run an extra wire off the number plate.
Pete
