2015 VX200 Central locking audible tone capability
antonio de lira
south_africa
Hi
I have a 2015 Land cruiser vx 200 , when i lock/unlock the vehicle there is no "beep" , I have checked the user manual and found that this function can be turned on/off via the vehicles radio.
In the settings menu i found that there are two settings that can be changed in the "locking" menu, the hazards flash on/off when locking/unlocking and the beeper volume can be adjusted.
However the beeper is set to max volume but there is no Beep or audible tone when locking.
I took it to a Toyota dealer and was told that this function is not available on that model, i find this hard to believe as the function is on the radio and can be set.
Does anyone know where i can find the buzzer on the vehicle to check if its working or not?, or perhaps fit a buzzer should it not have one?.
any help would be appreciated.
thank you
