22re not starting
Mario90
hellooo,
Having issues with 22re and its progressively worsening running, up to the point it doesn't start because of over fuelling.
ECU has no error codes, injectors are supposedly fine, fuel pump is fine, the remaining bit is the fuel pressure regulating system.
Any hints how to test it? I think the ECU controls the vacuum to the pressure regulator on the rail.
