nathanrobo
- Apr 6, 2010
Guys,
I went up to Dudley today... booted it most of the way (80 -90) - shortly after turning onto the M5 I noticed that I was loosing power
I managed to limp home 50 - 60 (if I pushed any harder if felt like it was about to die, same when going up steep hills).
Got home and changed the fuel filter, when I pulled off the fuel pipes neither of them appeared to have any fuel in (although the filter had a bit) and the filter was very gungy. On fitting the new filter, the priming button didn't seem to pull any fuel through. So I took the filter off, filled it with fuel, refitted and tried to start - surprisingly it did, but on a test drive it felt the same, lacking power as if it was on limp home mode, not sure if I can hear the turbo either.
Question is how do I know if I have a turbo problem or fuel starvation from some component between the tank and filter. For example is there a tank lift pump? the manual mentions a fuel solenoid, where is this located? Oh and sometimes there is blue smoke when I try to rev hard, most of the time the exhaust is realy clean.
