75 series windscreen surround removal
Big75
australia
Hey can someone give me some advice, I need to remove my 75 series windscreen surround to fix up a bit of rust and replace the windscreen and lower seal.
I’ve heard it can be done without taking the roof off and I don’t have any new roof seals so I’d rather not remove it!
Mine doesn’t have the fold down windscreen if that helps. Does anyone know can it be done and if so how is it just those 4 bolts either side?
Thanks
I only have experience with the 70 FRP top. The drop screen frame with the FRP top cant be removed without first lifting the roof. There is a bar forming the top of the door frame which is bolted to it and the bolts can only be accessed with the roof off.
I don't know if this is the same with yours. Check out the top of the screen frame where it meets the top bar and see how it's fixed.
