- May 27, 2010
Ok, thanks, not the one I was thinking of then, the one I'm thinking of is the relay for the starter but probably is the relay , for the relay, if you get my grift, as I've changed mine for a regular standard 24 volt relay, just crimped on new spade connections, mine had been hanging upside down when I got the car, full of water so when turned the right way up, it went belly up. I'll stop there as I don't want to confuse the issue, or myself. Thanks againBill, I believe the one you are referring to is the heater plug relay if it's the one in a sealed can a bit like a corned beef tin. The one referred to is behind the LH battery (as from the drivers view), I think in front of the fuel filter assembly with approximately a 4"x 3" black plastic cover. It has several of the heaviest cables on the vehicle going to it.
