80 Series OEM wheel carrier
Mblinko
This is a genuine JDM carrier complete with all the parts needed to fit to your 80 (Except the upper strengthener which is fitted at build time at the factory and cannot be extracted.) Please note though, that the carrier itself is slightly bent, it having been rear ended at some time. Hinges and structure are all fine and the photos are of it fitted to my car. You can see by how much it it is bent in the photos. I do not have the facilities to straighten it but it will be easy for someone with time and a big lever. £150 ono . Collect only.
Ok. If it stops raining I'll pop out to my truck and just check a couple of things over. I'll get back to you. Only in wisbech
Can’t do today mate. Any other day is fine.
I got one for my truck. I'd give £50 if it's any good to cut up for bits. Have an idea but not sure if it will work yet.
