Ive been prepping the 80 for its mot over the last few weeks, and came to look at the rear diff lock. I had done it up a few years back, worked, then stopped working, didn't really look at it then. Now it looks like a swollen mushroom. Actually broke in half when taking it off, screws had snapped holding the cover on, inside was total mince.
Whats salvageable is:
The plug and wires going into the body (pins are good)
Big and small gears with the return spring
The main rod that moves back and forwards
The plate with the 3 contacts
Cover plate that goes over the gear wheel (corrosion will clean off)
The magnet cap and motor are sort of one corroded piece, the magnets should come off with care, steel cap is past it, and motor shaft looks abit bent.
Taking offers for whats usable, might save someone a few hundred quid if buying a new one.
