1994 80 VX Auto Off Roader with lots of kit
jjsaul
Finally got round to listing on here....had this a few years and some of you will remember it from outings to Lincomb. I've not really had much use with it recently and I'm trying to downsize the storage space we have, so it's got to go.
1994 12v Auto VX 80
Loads of kit on it, listed below.
Located in Yorkshire, LS21.
Not MoT'd, as I haven't had it out of our unit for ages, been stored undercover.
Rebuild prior to my ownership includes;
Galvanised Chassis, New front, Centre and Rear Diff Locks, 4 Inch Lift Kit from Superior Engineering, Ironman foam cell Competition shockers, Ironman Springs, Superior Panhard Rods and Drag Arms, Superior Superflex Front Arms, Superior Adjuster Bars, Rear Diff rebuild including Every Bearing and Seal, Reduced Ratio 4.56 Nitro Crown-wheel and Pinion, Nitro Invincible Half Shafts, New Discs, New Calipers, Brake Pads and Handbrake Shoes, Axle Wader Pipes, Polybushed throughout, Front Diff rebuild, same as rear with Nitro Chromolly, Nitro Extreme CV Joints and Shafts, Reduced Radio 4.56 Nitro Crown-wheel and Pinion, Nitro Invincible Half Shafts, Axle Wader Pipes, Steel Braded Brake Hoses, Tough Dog Steering Damper, Purpose Made Steel Bumpers, Bush Cables, CB Radio, New Engine and Gearbox Mounts, New Sump, Water Pump, Radiator, Air Con Radiator, Diff Protectors, Gearbox Protector Plates,2 New Batteries, Auto Box Filters changed, Transfer Box Seals replaced, All oils and filters changed, PAS Box overhauled by Specialist, Full Exhaust, Professionally rebuild Turbo, New Cambelt and Rollers, New Brake Master Cylinder, 37 Inch Bedlock Mudzilla Tyres, Massive Warn 16.5 Tonne Winch, Cut out arches and mudguards, Snorkel, Pin 7 Mod done for Centre Diff Lock.
07711 279499 - call / whatsapp
£8000 ono
