- Mar 1, 2010
What I did with mine was to have my wife crank the engine with me holding a voltmeter on the batteries. "Click Click Click" , 3 volts and there you go.
Unfortunately the write up on these testers reads good, but they cannot do a 'real' load test. You only have to look at the terminals to see that. Even modern testers look at the voltage and tell you all good, and then a 'pulse' is sent through the battery and this confirms the connections inside the battery are in good order and the amount of plate sulphation is low, but like the voltage the pulse puts a minimal load on the battery as a whole. The amount of DIY customers who have these style of testers want to argue that their battery does not need replacing because the green light is on you simply would not believe, only when I put a 'proper' load tester on the battery which mimics cranking do they agree to a new battery.
Maybe it depends on the tester, but the ones I've seen give a measurement of internal resistance, which would be high if the connections between the plates were knackered?The problem is that these modern systems do not test the integrity of the internal connections, now no longer visible like 'old' batteries they are often forgotten about.
I've converted mine to 12 volt start. One battery is more than capable to run the starter etc so I just use one battery connected so I always have a spare. i "rotate" the batteries every few months and keep the disconnected one on trickle. Current Vartas are 5 years old !!
Halfords will do a free battery test
