again
There is also a filter below the stop valve.
Julian
Email: [Email address removed]
Mobile:=A0+44 (0)7971 540 362
Hi Guys
Thanks Clive, Julian where is the stop valve.
john 92HDJ 80 1HDT
I always get that wooshing noisse when I open my cap! But my 80 she
run like a cheetah, no problem. But my idle is always change. Does
this Walmart pusher pump come from USA or EU?
2008/5/5 Julian A.R. Voelcker <[Email address removed]>:
Hi
Not sure if it helps but i had an 'intermittent problem when i first got my
80. I thought it was the fuel pump as the previous owner said he had gone
through the fuel system., but he had missed the tank. To make sure get the
back seats out and you can get into the tank and clean the crud from the
pick up tube. Solved mine but the symptoms were not exactly the same...
I thought the 80 had a 'get me home' safety system that's to do with the AT
box if there is a fault ? When mine was rebuilt it got stuck in this mode
and it was a single broken wire.. not exactly an engine management but a
safety system of some kind ?!
Gareth
----- Original Message -----
To: <[Email address removed]>
Sent: Tuesday, May 06, 2008 8:56 PM
Subject: Re: [ELCO] again
Hi Bernard
Usually the Walbro pump can be bought in the USA or Aus.
cheers
john 92HDJ 80 1HDT
SNIP
. Does
Hi
Haven't paid to much attention to this blog but both my 80 series needed there fuel tanks removing and cleaning! the crap in both was substantial - this in both cases resolved the loss of power problem. both 93/94 and both approaching 200k
si> From: [Email address removed]> To: [Email address removed]> Subject: Re: [ELCO] again> Date: Tue, 6 May 2008 22:43:26 +0100> > Hi> Not sure if it helps but i had an 'intermittent problem when i first got my > 80. I thought it was the fuel pump as the previous owner said he had gone > through the fuel system., but he had missed the tank. To make sure get the > back seats out and you can get into the tank and clean the crud from the > pick up tube. Solved mine but the symptoms were not exactly the same...> I thought the 80 had a 'get me home' safety system that's to do with the AT > box if there is a fault ? When mine was rebuilt it got stuck in this mode > and it was a single broken wire.. not exactly an engine management but a > safety system of some kind ?!> Cheers> Gareth> ----- Original Message ----- > From: "Benoit Bernard" <[Email address removed]>> To: <[Email address removed]>> Sent: Tuesday, May 06, 2008 8:56 PM> Subject: Re: [ELCO] again> > > >I always get that wooshing noisse when I open my cap! But my 80 she> > run like a cheetah, no problem. But my idle is always change. Does> > this Walmart pusher pump come from USA or EU?> >> > 2008/5/5 Julian A.R. Voelcker <[Email address removed]>:> >> Yes, that's the case with 80s and I think also 90s like yours.> >>> >> One of the problems with brimming your tank is that it can lead to the > >> vent in the filler cap getting gummed up.> >>> >> If you hear a whooshing sound when you remove the filler cap the chances > >> are that the cap is a bit gummed up. If you are careful and watch the > >> spring it is possible to strip the cap down, clean it out, etc. When you > >> do it you can use one of the silicone based dry lube products to > >> lubricate the valve so it opens more easily.> >>> >> If you are getting the whooshing noise it is worth sorting out because it > >> puts more pressure on your injection pump and can lead to fuel starvation > >> at higher revs (80s struggle with this anyway, but you can counter that > >> by fitting a Walbro pusher pump).> >>> >>> >> Regards,> >>> >> Julian Voelcker> >> 07971 540362> >> [Email address removed]--> >> European Land Cruiser Owners Mailing List> >> Further Info: http://www.landcruisers.info/lists/> >>> > --> > European Land Cruiser Owners Mailing List> > Further Info: http://www.landcruisers.info/lists/> > > > --> European Land Cruiser Owners Mailing List> Further Info: http://www.landcruisers.info/lists/
All new Live Search at Live.com
http://clk.atdmt.com/UKM/go/msnnkmgl0010000006ukm/direct/01/
Hi Clive,
The TPS on top of your injection pump may well be for the transmission ECU.
Unless yours is a very unusual variant it won't have an engine ECU. Either
way having the TPS incorrectly connected will cause problems.
IIRC John's car is a fairly early 80 so probably has the all hydraulic auto
box with no ECU?
All the best,
Toby
1990 HDJ80 UK
Hello the guys this remind me,
Today I passe MOT and they tell me my near side wheel is loose! Well I
go crank on it myself and wholy crap they is right, it is loose. So I
take off the wheel and get readys to tightens up the wheel bearing
roulement. Que merde! There is a driven hand "main meneuse" like on
my Range Rover! Well the front axles does float. So Einstein there is
no screw visible to adjuster.
So I musts take off the driven hand and find that big nuts behind it
to adjust my front wheel bearing. Do you have some archievs to tell me
how to do it?
2008/5/4 john byrne <[Email address removed]>:
how to do it?
2008/5/7 Toby Welburn <[Email address removed]>:
