Rob Cowell
- Nov 15, 2011
Airbag light has been coming on for a while so I thought I better take a look. And it's the MOT this month and airbag lights are a failure, right? Gone through the diagnostics in the repair manual and I think it's this. No resistance reading at all between these two wires, and yes the multimeter is working.
OK, instrument panel wire. Sounds like something that goes to the instrument panel. So, now I know how to remove an instrument panel, assuming thats the speedo doodah. Not too bad. Only no sign of a yellow, or yellow/blue wire which is what comes out of the connector onto the spiral cable. Well, those wires might be going to the panel but there are a gazillion other wires there so I thought I better consult the wiring diagram.
Hmm. Airbag squib has yellow, and yellow and blue wires (the instrument panel wire) but no mention of them going to an instrument panel. I think the "airbag sensor assembly" is the "centre airbag sensor assembly" which is under the arm rest / box doofah.
Wiring is not my strong point. Does my interpretation look correct? Anyone had to do any of this? Like to offer any words of wisdom? I'm off to put the instrument panel back (speedo binnacle thingy) back.
