Air Con pump
Re the starter:
If you have a diesel with twin batteries and 12v/24v changeover for starting this *can* be a symptom of a duff cell in one battery, rather than a fault with the starter itself.
What happens is that in normal (batteries in parallel, 12v) mode the good battery masks the failure of the bad one, and everything works fine. It's only when you swap to series (24v) mode to start that the duff cell reduces the voltage and current to the starter, resulting in less than 100% engagement and thus getting stuck. There are no other symptoms or warnings to speak of.
Been there, done that, and had the starter rebuilt twice only to find that the problem was the batteries!
To check them you must first isolate them from one another, then test them separately. Well worth doing before taking the starter apart.
Christopher Bell
Devon, UK
1008 1HD-FT
Hi Julian
=A0
any luck with the aircon pump?
=A0
Also my starter motor has stuck on a couple of times, has needed an knock to stop it trying to turn over - so presume it is probably on its way out?
=A0
Chris,
Get a starter motor re-build kit and replace the contacts. One of the
contacts wears more than the other, resulting in the contact ring sticking
as it is skewed. This usually happens when you have started the engine, ie:
it sticks on, not off.
2008/10/16 chris coombs <[Email address removed]>
> Hi Julian
> Chris
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
SGkgQ2hyaXMsDQoNCkl0IHNob3VsZG4ndCBiZSBhIHByb2JsZW0gZ2V0dGluZyBhIHNlY29uZCBo
YW5kIGFpciBjb24gcHVtcCwgSSBoYXZlIG9uZSBoZXJlIHRoYXQgSSB3YXMgZ29pbmcgdG8gcHV0
IG9udG8gbXkgdHJ1Y2ssIGJ1dCB5b3UgY291bGQgaGF2ZSB0aGF0Lg0KDQpJIHdvdWxkIGFsc28g
cnVuIHdpdGggQ2hyaXMnIGRpYWdub3NpcyBvbiB0aGUgc3RhcnRlciBtb3RvciAtIEkgYWxzbyBo
YXZlIHRoZSByZWJ1aWxkIGtpdHMgaGVyZSA6LSkNCg0KUmVnYXJkcw0KSnVsaWFuDQpFbWFpbDog
anVsaWFuQHZvZWxja2VyLmNvLnVrDQpUZWw6wqArNDQgKDApODQ1IDUwOCA2ODYzDQo
Julian,
Ahem.
2008/10/18 Julian A.R. Voelcker <[Email address removed]>
> Hi Chris,
> It shouldn't be a problem getting a second hand air con pump, I have one
> here that I was going to put onto my truck, but you could have that.
> I would also run with Chris' diagnosis on the starter motor - I also have
> the rebuild kits here :-)
> Regards
> Julian
> Email: [Email address removed]
> Tel: +44 (0)845 508 6863
Clive Marks
I think Clive was hinting that it was he who suggested starter rebuild kit
not Chris as you said in you message Julian.
Ian
