Aircon problem
Airhoguk
On a hot day after about 20-30 minutes of running my zircon starts to slowly warm up and increase fan speed to try and compensate. Then at least one of the vents start to pump out what looks like white smoke or dry ice. I've checked the level of refrigerant with a gauge which seems to be fine and changed the pollen filter which was filthy and full of bits of leaves. Any ideas? :pray:
Does not happen on mine but a friends Honda will pump out white mist on a hot day. Its just condensation.
Could your exchanger be freezing up which stops the air? Lots of dripping water under the lc?
There are others here who know more about aircons than I...
Sent from my GT-P7510 using Tapatalk 2
