Annoying running problems - LPG
Peter,
I've had the exact same issue years ago in Scotland but kinda in reverse
Petrol ran fine and LPG was really wonky (as u describe)
Then it went away (my LPG guy tweaked it but never found the problem)
Then months later it reversed itself (fine on LPG but sucked on petrol)
Again it went away and never found the issue.
I though it was an intermitent grounding of wires or something but checked
the harness issue that other (some) TLC's found behind glove box and on
other side of firewall. But my wires were all fine - no breaks or grounding.
Based on the hesistancy it sounds like a vacuum leak, but why run fine on
LPG (I presume yours goes into airflow/intake near trottle body and its not
injection feed?). Don't make sense.
Lal in Colorado (US 96 petrol FZJ80 truck) and is just starting back up his
LPG after 1.5 yrs of non-use as petrol prices $3/gal and Propane/LPG at
$1.85. Yah. yah its nothing compared to the $6/gal ye guys are paying but
I'm not used to putting $50+ into my truck.
Anyways I had a very corroded solonoid on the vaporise that wasn't working
and now its fine, as long as I don't go above 1700 recs (25mph!) otherwise
it kinda cuts it there :) No I'm gonna check my lpg filers and steeper
motor over the w/e
-----Original Message-----
[mailto:[Email address removed]]On Behalf Of Julian Voelcker
Sent: Thursday, September 15, 2005 10:36 AM
To: [Email address removed]
Subject: Re: [ELCO] Annoying rough running problem
Hi Peter,
Yes, as long as you make them small, otherwise fire them over to me and
I'll take a look.
The only other person I know with experience of the petrols is Andy
Bell, but he's been a bit quiet.
Also, Brendan Lally (are you there?) might be able to help - he has a
UK gas conversion over in the US.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
Hi Lal
is
You guys are so lucky ;-). I have 150 liters deposit at 1.034 euro
/liter every time I fill up I commonly "put" 150 euros in the deposit.
Or about 180 USD.
Fortunately at about 20000 km/year I really don't care that much.
Joaquim 94 1HD-T Portugal
Hi Joaquim,
And so are you - at the moment most Diesel in the UK is around ?1 per
litre = ?1.47 Euro per Litre or $1.81 US Dollars per litre!
Hi Joaquim,
SGkgSnVsaWFuCj4gQW5kIHNvIGFyZSB5b3UgLSBhdCB0aGUgbW9tZW50IG1vc3QgRGllc2VsIGlu
IHRoZSBVSyBpcyBhcm91bmQgozEgcGVyCj4gbGl0cmUgPSCAMS40NyBFdXJvIHBlciBMaXRyZSBv
ciAkMS44MSBVUyBEb2xsYXJzIHBlciBsaXRyZSEKCkkga25vdywgSSBrbm93LiBUaGVyZSBpcyBh
bHdheXMgc29tZW9uZSBsdWNraWVyIGFuZCB1bmx1Y2tpZXIgdGhhbiB5b3UuCgpMZXQncyBob3Bl
IHRoZW4gdGhhdCBwcmljZXMgb3ZlciBoZXJlIHdvbid0IHdlbnQgdG8gMS41IGV1cm8vbCBzbyB0
aGF0CnRoZSBwcmljZXMgaW4gVUsgd29uJ3Qgd2VudCB0byB0aGUgYXN0b25pc2hpbmcgMiBldXJv
cy9saXRlci4KClJlZ2FyZHMKSm9hcXVpbQo5NCAxSEQtVCBQb3J0dWdhbAo
