Auto box on 71 series
Hello guys,
I'd like to change the oil in the auto box on my KZJ71 TLC before the end of
the month to be ready for Salisbury plain. Not having done this in the past
and needing to check out what to do I could not find a clear process on the
internet, so climbed underneath and saw the drain plug, but did not see
where to refil.
Also, do I need take the bottom off to inspect/clean/replace the filter (I
guess it will have one). The TLC now have 132 000 KM on the clock.
One of my biggest problems is locating a maintenance manual for my Jap
import 1993 model 71 series. I found a manual for the 3L 1KZ-TE, but this
only covers the engine and excludes the gearbox, transfer case etc.
Dirk
The content of this e-mail and any attachment is private and may be legally
privileged. If you are not
the intended recipient, any use, disclosure, copying or forwarding of this
e-mail and/or its
attachments is unauthorised. If you have received this e-mail in error
please notify the sender by e-
mail and delete this message and any attachments immediately from this
system.
Kingston Communications (HULL) PLC is a public limited company incorporated
in England and Wales
with registration number 02150618 and whose registered office is at 37 Carr
Lane, Hull HU1 3RE
Hi Dirk,
If your auto box is anything like the one in the 80, there won't be a
filter as such, but a sieve that might need cleaning, although the
mileage is still relatively low - if theoil looks a bit dirty then
might be worth it.
You will probably have to fill it from the dip stick tube - a real
fiddly pain in the rear, but not something that you have to do that
often so not a major hardship.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Hi Dirk,
This is the method I use assuming you are changing the trash filter in
the sump.
Drain the oil from the pan and remove the pan and filter. Now measure
how many liters of oil you got out. You should be able to buy a
aftermarket cork pan gasket rather than have to glue it on like the
factory does. If so clean and dry the gasket faces and apply a very fine
film of Loctite 515 to both sides of the gasket (if any gets into the
auto it does not matter as it will dissolve in the ATF and do no harm
unlike RTV) and refit the pan tighten the bolts gently so you don't
split the cork gasket.
Buy an ATF funnel if you don't have one, basically a big funnel with a
very small outlet to fit in the dipstick tube.
Now put in through the dipstick tube the same number of liters as you
have taken out initially. Say 4L if we assume the total capacity is 12L
(a 80 series is 16.5L) we still need to replace another 8L. Don't start
the engine yet.
Go to the back of the radiator and undo the clips on the two rubber
hoses that attach to the radiator pull these two hoses off and point
them down into a bucket. While you watch the hoses get someone to start
the truck (while in park) when you see oil being pumped out of one hose
stop the truck. Recconect this hose to the oil cooler in the rad (this
is so you flush out the oil cooler with fresh clean oil). Now connect
the other one and disconnect the other end of this hose and point it
into the bucket. Now when you start the truck the oil is being sucked up
out of the auto sump and pushed through the oil cooler and dumped into
your bucket with no oil being returned to the sump.
Now start the truck and run it until the hose in the bucket gurgles a
bit now turn off the engine. Check how much has come out say another 4L
so we are now upto 8L replaced.
Repeat until you have removed 12-14L of oil into total. Recoonect hose
and top up the auto level. It should be checked in park with the engine
running after shifting through all the gears. Once the level starts to
move up the dipstick it will rise quite rapidly so fine tune at 1/2L at
a time. It will take several dips to clean out the dregs running down
the dipstick tube from filling it to get a accurate reading after
filling down the dipstick tube.
You have now successfully replaced all the fluid with minimal cross
contamination.
Note to John Byrne: You can do your 80 in exactly the same way John when
you switch to Amsoil if you start with 19L and end up with 1-2 left over
that is about right.
Cheers,
Craig Vincent
HDJ80 VX LTD Auto, 11/96
Maartens transcooler, Sport turbo & intercooler, Rodney's Extreme II
Valvebody, 3.5" Flowmaster, Walbro 6065, Bilsteins, pyro, boost, pre &
post intercooler, & transtemp gauges
Christchurch,
New Zealand.
Dirk Theron wrote:
> Hello guys,
> end of the month to be ready for Salisbury plain. Not having done this
> in the past and needing to check out what to do I could not find a
> clear process on the internet, so climbed underneath and saw the drain
> plug, but did not see where to refil.
> filter (I guess it will have one). The TLC now have 132 000 KM on the
> clock.
> this only covers the engine and excludes the gearbox, transfer case etc.
> Cheers
> Dirk
> legally privileged. If you are not
> this e-mail and/or its
> system.
> incorporated in England and Wales
> Carr Lane, Hull HU1 3RE
Hello Craig/Julian,
Many thanks for your replies, I'll have a play this weekend.
Dirk
> Hi Dirk,
> This is the method I use assuming you are changing the trash filter in the
sump.
> Drain the oil from the pan and remove the pan and filter. Now measure how
many liters of oil you got out. You should be able to buy a aftermarket cork
>pan gasket rather than have to glue it on like the factory does. If so
clean and dry the gasket faces and apply a very fine film of Loctite 515 to
both sides of >the gasket (if any gets into the auto it does not matter as
it will dissolve in the ATF and do no harm unlike RTV) and refit the pan
tighten the bolts gently so >you don't split the cork gasket.
>Now put in through the dipstick tube the same number of liters as you have
taken out initially. Say 4L if we assume the total capacity is 12L (a 80
series is >16.5L) we still need to replace another 8L. Don't start the
engine yet.
>Go to the back of the radiator and undo the clips on the two rubber hoses
that attach to the radiator pull these two hoses off and point them down
into a >bucket. While you watch the hoses get someone to start the truck
(while in park) when you see oil being pumped out of one hose stop the
truck. Recconect >this hose to the oil cooler in the rad (this is so you
flush out the oil cooler with fresh clean oil). Now connect the other one
and disconnect the other end of >this hose and point it into the bucket. Now
when you start the truck the oil is being sucked up out of the auto sump and
pushed through the oil cooler and >dumped into your bucket with no oil being
>Now start the truck and run it until the hose in the bucket gurgles a bit
now turn off the engine. Check how much has come out say another 4L so we
are >now upto 8L replaced.
>Repeat until you have removed 12-14L of oil into total. Recoonect hose and
top up the auto level. It should be checked in park with the engine running
after >shifting through all the gears. Once the level starts to move up the
dipstick it will rise quite rapidly so fine tune at 1/2L at a time. It will
take several dips to >clean out the dregs running down the dipstick tube
from filling it to get a accurate reading after filling down the dipstick
tube.
contamination.
e-mail and/or its
system.
Lane, Hull HU1 3RE
