Paul
As there is definatly something amiss with the auto box on mine the investigations will begin.
Firstly i will do a fluid change to see whats happens, but the local dealer tells me there is no filter inside the box, is this correct? He says they have never changed one. Also, are there any recommendations for the fluid different from standard? And the capacity?
I am keen to get it all out so any tips for getting more than a normal drain? I have read the thread on the valve body replacement allowing lots more to come out when loosening the bolts so will try this. Any drains on the Torque Converter?
Will post results in case i have to move onto a rebuild of TC and box.
