Billing
-----Original Message-----
On Behalf Of Dyfed Bowen
Don't know yet.
A billing regular was telling me this morning it's much better to go on
the first day, there are better deals to be had, so I don't know if I'll
still be there at the weekend after all, have to wait and see.
Best Regards,
Jon.
Jeremy
Count me in (if I can afford the Diesel I'll be there)
Renate
>>> [Email address removed] 05/10/05 05:32pm >>>
I will be there. Fancy a poke around to see if I can find something
useful
for my 3 month N Africa trip in september. Also be good to meet some
other
elco people as I missed the Salisbury day.
Jeremy
On 10/5/05 16:57, "dyfed bowen" <[Email address removed]> wrote:
> so then
> hands up who are going?
> moi!
> Quoting Jeremy Llewellyn-Jones <[Email address removed]>:
>> Renate
>> Info about the LR enthusiasts show at Billing is here:
>> www.landroverenthusiast.com/billing/
>> Jeremy
>> PS better late than never...
>> European Land Cruiser Owners Mailing List
>> Further Info: http://www.landcruisers.info/lists/
Hi all
I'm going to Billing on Sunday and wondered if anyone knew what time it all
kicked off in the morning. Intend to get there early if poss.
Jeremy
Mob: 07831 458 793
On 7/13/05, Jeremy Llewellyn-Jones <[Email address removed]> wrote:
ll
Jeremy,
It all depends how long the beer parties last into the night and
Saturday is no exception. Most sellers kinck in around 9 am,. but it's
wise to come earlier to find a good parking space. If you buy a bulky
item and want to put it to your car, you may need to walk half a mile
extra if you're parked at the far end of the field
Rgds,
Roman (London, UK)
'92 HDJ80
On 7/13/05, [Email address removed] <[Email address removed]> wrote:
Yes. I'm hoping to go on Sat and stay for the weekend, that is unless
I spend all the money on Saturday and if the weather permits
Rgds,
Roman (London, UK)
'92 HDJ80
h
n
Mmmm.... getting paid for doing work on my own LC! That's the stuff of
my dreams!
If are going to replace the hub bolt for front axle (Part No
90942-02049) you'll also need the seals and tab washer for the hub
reassembly.
If it's only one and all the other bolts have not been overtightened
(I am wondring why this one broke ???), the wheel should not (with
luck!) fall off when driven for a few hundred miles. I had this
problem once in Libya and I never bothered to replace the bolt until I
came back to the UK.
Rgds,
Roman (London, UK)
'92 HDJ80
What special tool are you going to use? I'm intrigued.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
On 7/13/05, Julian Voelcker <[Email address removed]> wrote:
Lady-size hammer?
I'll take my coat .....
Rgds,
Roman (London, UK)
'92 HDJ80
Renate, you need to take the calliper off, then the hub. On the front of
the hub you'll see 6 (I think) bolts that hold the disc onto the hub -
undo those and you can separate the disc from the hub with some gentle
persuasion. With the disc removed from the hub you can see the back of
the wheel studs. Get a drift of some sort, for example a bit or steel
bar about 10mm diameter and 6" long. Use the drift to hammer the old
stud out the back of the hub. Push the new stud into place and find some
packing washers or similar so that by tightening the wheel nut onto the
new stuff it pulls it through. Make sure the stud is coming through
square on to the hub though otherwise they bend, best if you have a
couple of studs to hand just in case.
As Roman said you need lock washers and a gasket for the hub as well
when you put it back together. I have always managed just fine using
this method and have at various times replaced all 12 front studs, no
blow torch or hydraulic press should be needed.
It's not a big job Renate if you have the spares ready before hand.
Best Regards,
Jon.
On Behalf Of [Email address removed]
Sent: 13 July 2005 13:18
To: [Email address removed]
Subject: Re: [ELCO] Billing
Roman
Its not the hub bolt on the axle that's gone, its only the wheel bolt -
we
had a similar problem in 2000 in Libya too with wheel bolts - my mate
didn't do much with it for a few days, but we did saw through the
opposite
one as the wheel was unevenly balanced on five - which is what mine is -
its just an ionconvenience, I can probably sort it out with a drill, and
a
special tool...which I'm acquiring on this Friday coming - hopefully, it
will all be done for Saturday so I can leave for Billing in good time to
arrive there for the evening.
Renate
bit
(when I
Unfortunately I will have to drop out of going to Billing due to a
family commitment, but I hope you all have a great time.
It looks like it will be quite hot so be prepared take some suntan
cream - I went to an event last weekend and was staggered by the number
of people wandering around looking beetroot red from the sunburn.
Just checked the link and its gone. Renate must have bought it. If you are
interested it is a diesel powered trike that is on E-bay. It is there as I
can find it by searching for diesel trike but not using the link.
Simon Hughes
Hi Renate
Sorry to hear about the state of your finances. It would have been good to
have met up at Billing (I can't go, I have a list the length of your arm
that needs doing to the car, the house and the garden and I could go on all
day) but we will all get together at some point.
Roman and Julian seem to have found issue over ID cards etc. Frankly I
don't care what they do as long as they do something. I have nothing to
hide so don't care about having an ID card. Freedom and liberty are all
very well till someone blows up your child/wife/parent. What they need to
do is to root out extremism hiding behind religion.
Simon Hughes
Hi,
If any of you are up at Billing this Friday, let's meet up. I'll be on 07971 540362.
Julian
Email: [Email address removed]
Tel:=A0+44 (0)845 508 6863
Off to Farnborough this weekend following the total washout at Fairford.
Have a good time.
Pete
