(Birfields)( 80)
Hi Guys
I have another question for you, thanks Julian for the other answer. Is it
possible to get a maintainance list off someone that is easy to follow for
all the bits and pieces. I ask this because I would like to know is there a
set time/interval for to replace or maintain the birfields and bearings.
John C
92HDJ 80 1HDT Ireland
Hi John,
I don't think there is a set maintenance interval because it really
depends on the amount of work they are doing.
Toyota only look at them if there is a problem.
However it is generally recommended to check and repack around every 20-
30,000 miles.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
On 7/20/05, Julian Voelcker <[Email address removed]> wrote:
Hello guys,
There is a routine maintenance list compiled by toyota Gibraltar (
http://tinyurl.com/e3o7c ) but it refers to vehicles working in ardous
conditions. When using a LC for school runs and weekend trips you
don't need to repack the birfields every three thousand miles :-)
Rgds,
Roman (London, UK)
'92 HDJ80
