Brake master cylinder
Craigmorley
Hi need help brakes have gone completely now master cylinder is knakered does any one know what other model master cylinder fits a k reg lj70
what about kzj70 one looks the same.. Surely ital be the same??
The lj70's master cylinder has 7 / 8 diameter stamped on the side and the earlier import and later kzj70 etc with the bigger brakes has 15/16 stamped on it. I don't think the 80 series one would fit. As a replacement you can fit a hilux surf master cylinder. . Hope this helps
Iwan master cylinder is a lot different to mine starting to think it wasn't Evan the one for it as the brakes have always been terrible but now they brilliant thanks Iwan :icon-biggrin:
I have a BJ74 and just put a 1990-92 80 series brake master cylinder in... I just had to make a special bracket to hold the heat shield but otherwise it fit perfect. It also sets me up better for rear disc in the future.
Rich hi what model and have you got any pics? Many thanks craig
