- Feb 2, 2013
My local wheel alignment centre said the caster is seized and adjustment is impossible quite some time ago so i've been regularly soaking them in GT85 , yesterday i tried without success to free them off so i took the truck to a garage i trust but unfortunately does not have alignment facilities and they put the truck up on a lift and loosened all the nuts for me . Booked in for this afternoon to get the adjustments done at the original place and was told again everything seized and can't be adjusted with the added advice that the rear camber cannot be adjusted anyway .
I must conclude they just don't want to do it . I have found another place not to far away with the right equipment so i'm gonna try there but before i do i wanted to ask on here if it's true that the rear wheel camber cannot be altered ?
