- Aug 15, 2016
Jack one wheel up you should be able to turn it if it has a viscous coupling it will have some resistance but will stil turn then engage Centre diff lock or put it in low range if you don't have a button then try to spin the wheel you should hear a clunk then you shouldn't be able to spin the wheel then disengage the diff lock/put it in high range and try to spin the wheel again you should get another clunk and the wheel will spin it is also a good way to release a wound up diff if there is no loose ground and reversing isn't working
Hi Dellboy and others
Ok will try the one wheel up at a time and let u know. I take it this has to be done to all 4 wheels independently?
Thx
C
