chassis build help needed
roy
scotland
check this out more holes than metal, just knocked of the loose scale and paint to reveal swiss cheese
i am building the rear chassis new and need some info please,
as the picture shows the rear chassis rails are not really there anymore,
what i am after is the number of holes on the underside of the rear chassis rail for mounting tow bar etc.
from what i have left i think there are 3 holes 2 with captive nuts,
can anyone tell me if there are more and the position ?
cheers
The towbar I have just has 2 bolts per side going on to bar nuts you tuck into the chassis. It's a genuine Toyota one. Don't think the towbar needs a third hole however the exhaust silencer is mounted very close so maybe the third hole is something to do with this? Can get some pics if you like
cheers it was more the underside i needed, i have looked for pictures of the underside of the frame but can not find any online, that illustrate the area i need.
i was just looking for conformation on the sizing for the three holes on the diagram, before i get welding it all up and cant make changes.
the back 2 are captive for the factory tow bar and the first of the holes is used in mounting the ASFIR fuel tank guard i have.
