Chassis
Hi, as some will know, I went through quite a saga with my LJ 78 a while
ago, I ended up having it rebuilt, engine, new custom radiator with larger
capacity, new fan, s/s exhaust etc,etc, had just run it in for 1500 Kms and
my other half lends it to her ex to pick up the kids, he drives it into a
ditch, result ,the chassis is 2cm out at the front, not a mark on the
vehicle and a changed tyre worked fine, can't quite bring myself to scrap
it, body is as new and so is the inside, 104.000 Kms and one owner before
me, shame to break it up, putting on a jig to straighten it is too expensive
,it drives ok but not wise perhaps to use it, anyone have any ideas?,
Chris.
Probus Sigma Lda
Avenida Comendador Augusto Luis Rodrigues
lt 3 r/e
3330-301
Gois
Coimbra Portugal
Tel: (00351) 235778020
(M -Port) (00351) 934622929
(M -UK) (0044) 7718914251
www.probuscap.com
This email and any attachments are confidential and may be legally
privileged. If you are not the intended recipient please note that any
disclosure, copying, distribution or any action taken or omitted to be taken
in reliance on it, is prohibited and may be unlawful. Please notify the
sender immediately and destroy the message and all copies. E-mail
transmission cannot be guaranteed as secure or error-free as information can
be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or
contain viruses. The sender does not accept liability for any errors or
omissions in the contents of this message which arise as a result of email
transmission. The views and opinions expressed herein and any attachments
are the sender's own, and may not reflect the views and opinions of Probus
Sigma or any of its subsidiaries or associated companies. This message is
provided for informational purposes and should not be construed as a
solicitation or offer to buy or sell any investment funds, securities or
related financial instruments.
Hi Chris,
Flog it in Morocco - I saw several cars over there with far worse bends
drving along ;-)
I would either go for straightening it or see if you can pick up a
replacement chassis from a scrap yard (assuming reasonable condition)
and swap it over.
Failing all that I am sure someone else would be willing to buy it from
you to do the work themselves.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
How does it feel to drive?
Malcolm Bagley
Stafford UK
FJ45 '75 & FJ45 '76
-----Original Message-----
Behalf Of Julian Voelcker
Sent: 07 June 2007 11:01
To: [Email address removed]
Subject: Re: [ELCO] Chassis
Hi Chris,
Checked by AVG Free Edition.
Version: 7.5.472 / Virus Database: 269.8.11/837 - Release Date: 06/06/2007
14:03
Opps, read the text again.
If it drives OK I wouldn=92t worry too much, I would try to straightened up a
bit. You might find some of the deviation is before mounts for the spring
etc, and if you have seen some of the home brew suspension modifications the
springs seem to allow for some alignment issues. (Imagine a worn set of
bushes and the deviation that allows).
If you find a nice flat car park do some heavy braking and acceleration,
straight ahead and with some steering applied =96 look for anything the
doesn=92t feel right, pulling to the side etc.
Malcolm Bagley
Stafford UK
FJ45 '75 & FJ45 '76
Behalf Of Chris Yates Smith
Sent: 06 June 2007 20:07
Subject: [ELCO] Chassis
14:03
