Dorro
- Dec 12, 2018
hi my 1998 landcrusier did not have any key fobs when I bought it so I bought a 15 euro set on eBay before I wired it up if I used the key in the drivers door all locks would open and close no problems if I pressed the central door lock on drivers door panel all doors would lock and unlock working perfect, so I went to work on wiring up car entry system it went like this ............
If your car already has a central locking system. You take both orange wires and the black ground wire and splice all 3 together with the ground wire on your vehicle.
Both yellow wires go with the red positive wire into a power wire on your car. And the white wires you wire into the close and open wires on the door lock.. Brown wires went to hazards lights all works great now have key fob to open and close the door only problem I have is if I just use the key in the door the drivers door only unlocks and the central locking button on inside door panel is not working any more have a blown a fuse for the central locking or am I missing something any help would be great
Mike
Mike
