Gilbert v H
- Apr 7, 2010
Hi
I connected an aircompressor to the cigarette lighter and tried to pump up the tyres. The compressor was going very slowly and after a couple of minutes it stopped working. It seems it destroyed the plug (fuse is still OK).
Funnally enough this exactly happened in my last Truck (you would think I should learn
I then connected the compressor to the lighter plug in my ML and it worked much faster and the plug also survived.
Is that a common problem on these Truck (not enough power, cant run a compressor)?
What to to best to get a good working plug in the car?
Gilbert
Gilbert
