- May 26, 2014
Can anyone recommend a reasonable compression tester for the 80 series?
ta.
ta.
ta.
Pretty much what beau said clive. I want something haĺf decent and with the right fittings first time.Aren’t they all much the same Mike? None of them are particularly expensive, like this one?
https://www.amazon.de/Draper-37442-Kompressionsprüfer-Ottomotoren-Adaptern/dp/B0001K9TV0/ref=sr_1_9?ie=UTF8&qid=1543261567&sr=8-9&keywords=compression+tester
Afaik the hdft doesn't have glowplugs, so a test involves taking out the injectors replace them with an adaptor.The one above is more for petrol engines. You'll want a diesel made one that can read up 500 PSI. Pretty sure our yota diesel compression are around 400-500PSI? Also make sure to get one with correct fittings. I check compression from the glow plug holes.
most of the petrol testers I have seen are no where near 500 psi, I would also like one that has the right connectors for the 1hd-t glow plugs and the 1hd-ft injector housing.I’m always ready to be corrected and I’m no diesel specialist, but AFAIK the 1HD has a compression ratio of circa 18:1 the one being atmospheric which is 1 BAR.
18 x 1 = 18 BAR so why would you need something as high as 40 BAR?
My 1HZ has a compression ratio of circa 24:1 so that would need something like 30 BAR to be on the safe side.
Not arguing, just interested and askin’....
its not for my motor mate. the engine in my 80 is stronger than god and sweeter than love!Good reply Frank... I'm guessing that it would be a specific service tool with the same shape as the injector to test it with and a new copper seal.
Why do you need to test it?
what does BAR mean clive?
its not for my motor mate. the engine in my 80 is stronger than god and sweeter than love!![]()
